Bluesound Player can be reset to Hotspot Mode using any of the following options:
Using the BluOS Controller App
Android/iOS - Force Hotspot Mode
, and select the required Bluesound Player.
- Tap the Home tab
> Settings button
> Diagnostics.
- Tap Force Hotspot Mode.
This erases the currently saved wireless configuration and removes the Player from the network. The LED Status Indicator turns solid Green.
Windows/macOS - Force Hotspot Mode
- In the BluOS Controller App, select the Player Drawer.
- Select the required Player.
- Under the left Navigation Drawer, select Help > Diagnostics.
- Select Force Hotspot Mode.
Using the Play/Pause Button on the Player
In instances where the configured router is out of range, whether due to the Player's relocation or the router being powered off or replaced, the Bluesound Player initiates a reconnection process, indicated by a continuous blinking of Green LED.
For Bluesound models with a pause/play button:
- Press that button for 7-8 seconds while the player is flashing green.
- That will cause a brief RED LED. Stop pressing then.
- There will be a brief BLUE LED, then solid GREEN, indicating hotspot mode.
Connect the Player to the Network
Refer to our Help Center article to connect the Player to the required network.
