BLS-KB17-505
The PULSE SUB is a wireless subwoofer that uses point-to-point technology, allowing it to easily pair to your existing PULSE SOUNDBAR. You can also pair the PULSE SUB with other Bluesound Generation 2 models with the help of the Bluesound RT100 wireless speaker link (sold separately). When you first plug in and turn on your PULSE SUB, the front LED will turn solid blue after about 15 seconds. After another 15 seconds, the front LED will go out.
Getting Started
- Remove the rubber stopper labeled Bluesound on the PULSE SUB
- Set the Crossover is set to 120Hz
- Set the Phase to 0º
- Set the three way stand by toggle to ON
- If pairing with a PULSE SOUNDBAR or RT100, set the volume to 5
- If connecting directly using a wired cable, set the volume to 9
- Replace the rubber stopper
Pairing with a PULSE SOUNDBAR
- Ensure the PULSE SOUNDBAR is on and connected to the network
- Play something through the PULSE SOUNDBAR to make sure the Player is not in Standby Mode
- Ensure the PULSE SUB is plugged in and powered ON
- Note the location of the small Pairing Button on the back of the PULSE SUB
- In the BluOS App, select the PULSE SOUNDBAR from the Rooms Drawer and press the Settings icon
- Scroll to the bottom and press Pair with Pulse Sub
- Press and hold the PAIRING button on the rear of the PULSE SUB for ten seconds then release the button - the front LED will blink green.
- The Pair with Pulse Sub status in the App will change to Pairing and then Connected
- The PULSE SUB LED will then again go out after 15 seconds
Pairing with an RT100
- Connect the RT100 to your Bluesound Player or 3rd party device as directed in the RT100 Quick Setup Guide
- Ensure that Player is on and connected to the network
- Play something through the Player to make sure the Player is not in Standby Mode
- Press and hold the Status/Pairing button on the RT100 for ten seconds then release the button - the LED will blink green.
- Both LEDs will then turn solid green and will again go out after 15 seconds
Notes
- Alternatively you can connect the PULSE SUB wired directly to any existing Bluesound Player Gen 2 Player or a Bluesound Gen 1 Powernode using Subwoofer Cable (not included)
- The Bluesound RT100 is not support by the original Bluesound Gen1 line up
