The following methods help you connect the Bluesound Player to the home network.
Wired
A wired connection to the network is simple and requires less setup. If you require a wired connection, connect the Player directly to the router or home network using the Ethernet cable.
Android/iOS - Wired Setup
- In the BluOS Controller app, navigate to the Players tab
and select the Bluesound Player, highlighting NEEDS SETUP.
- Select the required Player's Hotspot* from the My Players Window.
- Select or enter a Name for the Player/room, and tap Continue.
- When the Setup Complete screen is displayed, tap Finish.
Windows/macOS - Wired Setup
- In the BluOS Controller app, navigate to the Player Drawer and select the required Bluesound Player, highlighting NEEDS SETUP.
- Select the required Player's Hotspot* from the Add Player Window.
- Enter a Name for the Player/room, and click Next.
- When the All Done! screen is displayed, click Finish.
Wireless
A wireless connection allows you to place the Bluesound Player anywhere in the home but does require some setup. The process is straightforward but slightly differs between iOS and Android.
Note: Windows and Mac users, please see the instructions under Wireless Manual Setup below.
Android - Wireless Setup
- Launch the BluOS Controller App on an Android device. New Players Detected prompt is displayed – select Setup Now.
- If the prompt is not displayed, tap the Players tab
in the bottom navigation drawer to launch the Players screen.
- Tap the Add a Player button
in the upper-right corner.
- Tap Choose WiFi Network and select the required WiFi Network.
Note: If the required WiFi Network does not appear or is hidden, select Manual SSID Entry. Enter the Wireless SSID and select the Protection type the network uses.
Optional: Switch on Save WiFi Password for a simplified future setup.
- Enter the WiFi network Password and tap Continue.
- When the All done! screen is displayed, tap Finish.
iOS - Wireless Setup
- Launch the BluOS Controller App on an iOS device. New Players Detected prompt is displayed – select Setup Now.
- Select the required Player's Hotspot* from the My Players window under Needs Setup.
- The App discovers the WiFi network – currently connected by the iOS device.
Note: To connect to other WiFi networks, select Show Other Networks... - [Optional] Change Speaker Name
- Tap Next.
- Once the WiFi setup is complete, tap Done.
If the above methods do not work, or if you have BluOS Controller App installed on a Windows/macOS, perform the following steps:
- Open the Android/iOS or Windows/macOS device's WiFi Setting menu – look for the WiFi network matching the new Player's Hotspot* and join it.
- On your device, launch a web browser and visit http://10.1.2.3/ – the Player's Control Panel menu is displayed.
- Select Configure WiFi.
- Select the required WiFi Network from the Configure Wireless drop-down menu.
Note: If the required WiFi Network does not appear or is hidden, select Manual SSID Entry. Enter the Wireless SSID and select the Protection type the network uses. - Enter the WiFi network's Password.
- Select a Player name or enter a Custom name.
- Select Update and wait for the Player's Status Indicator LED to turn solid Blue – indicating that the Player has successfully joined your home WiFi network.
- The Android/iOS or Windows/macOS device automatically reconnects to the previous WiFi. If not, select the required WiFi network from the device's WiFi Setting menu.
- Launch the BluOS Controller App:
Android/iOS
- Tap the Players tab
- Select the required Player renamed in Step 6 from the My Players Window.
- When the Setup Complete / All done! screen is displayed, tap Finish.
Windows/macOS
- Select the required Bluesound Player, highlighting NEEDS SETUP from the Player Drawer.
- Select the required Player renamed in Step 6.
- When the All done! screen is displayed, click Finish.
Android/iOS
Wireless Setup over Ethernet
When you install a new router or if the other methods listed above do not work – perform the following steps to configure the Player to the required wireless network.
- Disconnect the power cord of the Player from the power outlet.
- Connect an Ethernet cable directly from the router to the Ethernet port of the Player.
- Connect the power cord of the Player to the power outlet.
- Wait until the Status Indicator LED of the Players turns solid Blue.
- Connect the Android/iOS or Windows/macOS device to the required WiFi network and launch the BluOS Controller App.
Android/iOS
and select the required Player.
- Navigate to the Home tab
and select the Settings button
in the upper right corner.
- Select Player > WiFi.
Windows/macOS
- Select the required Player from the Player Drawer.
- In the Navigation Drawer, select Settings > Player > WiFi.
Android/iOS
- Select Update.
- Wait for 5 minutes and disconnect the Player's power cord from the power outlet.
- Disconnect the Player's Ethernet cable and connect the Player's power cord to the power outlet.
Note
*Player's Hotspot – Player's unique network ID and default name. The network ID is listed as the product name followed by the last four digits in the MAC (Machine Access Control) address (example: NODE 2-001A). The complete 12-digit MAC address is printed on a sticker on the bottom or back panel of the Player.
