The Bluesound NODE ICON is a two-plug power product with no ground. It has a floating ground as it is the preferred grounding style for audiophiles. The NODE ICON does not have the provision to connect the signal ground of other chassis grounds. When using an XLR audio connection, you may hear a humming noise.
To resolve this issue, connect an analog audio RCA cable between the NODE ICON and the amplifier.
