You can modify the audio output of the Player by adjusting the audio settings in the BluOS Controller App.
Configure Audio Settings
To manage the audio output settings of the Player, perform the following steps:
Android/iOS - Configure Audio Settings
. The list of players connected to the BluOS Controller App is displayed.
- Select the required Player’s context menu (3 dots) and select Audio Settings to display the menu options.
Windows/macOS - Configure Audio Settings
- In the BluOS Controller App, select the Player Drawer.
- Select the required Player's context menu (3 dots) and select Audio Settings to display the menu options.
Note: Upgrade the BluOS firmware of your Player to get the latest Audio Settings menu options available for your Player. The Audio Settings menu options vary depending on the model of the Player.
- Available audio settings
| AUDIO SETTINGS | NODE ICON | NODE (N132) | NODE NANO | NODE X | NODE (N130) | NODE 2i | NODE 2 | NODE (N100) | DESCRIPTION |
Audio clock trim |
Enable to reduce jitter and increase audio clock timing precision when using an external DAC. Note: Not all DACs can handle this. If audible clippings or dropouts occur, disable Audio Clock Trim to avoid BluOS's accuracy setting from interfering with the external DAC's firmware. |
| Bass |
Adjust the Bass output levels of your Player. |
| Crossover |
Adjust the crossover between 40Hz and 200Hz – by default, set to 80Hz. When the Subwoofer option is enabled, everything above the crossover is filtered out and sent to the RCA and Speaker Outputs. The Player sends anything below the set crossover out of the Subwoofer (SUBW) OUT. |
MQA external DAC |
Enable this option when you require an MQA certified external DAC to handle MQA unfolding rather than the BluOS Player. Note: To enable MQA external DAC, you should enable the Output level fixed, disable – Tone Controls and Replay-gain. |
Output level fixed |
Enable to fix the volume of the BluOS Player at the maximum level. It helps when you control volume using the external device connected to the BluOS Player instead of the BluOS Controller App. |
| Output mode |
Select any of the following to configure the channel output on the BluOS Player:
| Replay-gain |
Select any of the following to configure consistent volume levels between tracks in the play queue:
BluOS uses the metadata of the selected audio track to configure consistent volume levels between tracks. |
| Reset All |
Restore the audio settings of the selected Player or Listening Mode to default factory settings. |
| Subwoofer |
Select any of the following to configure the Subwoofer setting:
When you pair a PULSE SUB+ with a BluOS player, selecting Subwoofer displays the PULSE SUB+ Audio Settings. |
| Tone Controls |
Enable to adjust your Player's Treble and Bass output levels. Notes:
| Treble |
Adjust the treble output levels of your Player. |
| Volume limits |
Set the upper and lower limit of volume controls in the BluOS Controller App. Modifying the upper or lower volume limits of the BluOS Player allows more fidelity when adjusting the volume. |
