Proximity: Customize how the touch button indicators behave by using the Players' proximity sensors.
- Enable Proximity: When enabled, the touch buttons will only light up when the proximity sensor detects nearby movement. When disabled, the touch buttons remain continuously lit.
- Proximity Timeout [0 ~ 10s]: Adjust the duration for which the touch button indicators stay active after motion or touch detection ends. Note: Available only when the Enable Proximity option is turned ON.
Enable Proximity sensor and Adjust Proximity Timeout
To enable the Proximity sensor on Bluesound Players, perform the following steps:
Android/iOS - Enable Proximity Sensor & Adjust Proximity Timeout
, and select the required Bluesound Player.
- Tap the Home tab
> Settings button
> Player.
- Tap Proximity.
- Toggle the Enable Proximity option ON to activate it.
Toggle it OFF to disable it. - Adjust the Proximity Timeout as required.
Windows/macOS - Enable Proximity Sensor & Adjust Proximity Timeout
- In the BluOS Controller App, select the Player Drawer and select the required Player.
- Under the left Navigation Drawer, select Settings > Player.
- Select Proximity.
Note:
- Proximity sensor is available on the following Bluesound models:
