The Indicator Brightness toggle is available in the Settings menu of the BluOS Controller app.
Adjust Indicator Brightness
To adjust the LED Indicator or Touchpad brightness on Bluesound Players, perform the following steps:
Android/iOS - Adjust Indicator Brightness
, and select the required Bluesound Player.
- Tap the Home tab
> Settings button
> Player.
- Tap the Indicator brightness and select any of the following options to modify the Player's LED:
- Normal (default brightness)
- Dima) (reduced brightness)
- Offb)
Windows/macOS - Adjust Indicator Brightness
- In the BluOS Controller App, select the Player Drawer and select the required Player.
- Under the left Navigation Drawer, select Settings > Player.
- Under the Indicator brightness, select any of the following options to modify the Player's LED:
- Offb)
Notes
- a)Dim is not available on the Bluesound Generation 1 models.
- b)Off is unavailable on the Bluesound NODE ICON, NODE (N132), NODE X, NODE (N130), and POWERNODE (N330) models when Proximity is disabled.
- Touchpad brightness is also adjusted using Indicator brightness.
