BLS-KB15-705
To disable the LED (Indicator Brightness) on Bluesound Players, perform the following steps:
- In the BluOS Controller App, select the Player Drawer
. The list of Players connected to the BluOS Controller App is displayed.
- Select the required Bluesound Player and exit the Player Drawer.
- In the left Navigation Drawer, select Settings. The Settings screen is displayed.
- Select Player > Indicator brightness.
- Select any of the following options to modify the LED (Indicator brightness):
- Normal (default brightness)
- Dim* (reduced brightness)
- Off
Notes
- *Dim is not available on the Bluesound Generation 1 models.
- Touchpad brightness is also adjusted using Indicator brightness.
