To access the technical information of the currently playing song or any song in the Playlist / Play Queue in the BluOS Controller App:
- Select the context menu (3 dots) to the right of the selected song and select Technical info.
Technical information provides the File location, Format, Sample rate, Sample size, and Audio Channels of the song from your music library.
