By creating a fixed group with your Bluesound Players, you can have your players work together to provide a specific listening experience different from the Standard grouping in the BluOS Controller App. After creating a fixed group, these players appear as a single player in your BluOS Controller App's Players tab /Player Drawer. You can create three different types of Fixed Groups in the BluOS Controller App.
- Home Theater Group. Learn more.
- Stereo Pair Group. Learn more.
- Multi Player Group
Multi-Player Group
A Multi-Player group acts similarly to standard grouping in the BluOS Controller App. The main advantage of a Multi-Player group is to group multiple players that should function together and not independently. Multi-Player Group appears as a single player in the Players tab of the BluOS Controller App.
Note: The Bluesound NODE (N130) / NODE X with USB Audio OUT source must be the first player selected in the group to prevent synchronization issues.
Creating a Multi-Player Group
To create a Multi-Player group, perform the following steps:
iOS/Android |
Windows/macOS |
Balancing or Adjusting Players in a Fixed Group
To adjust the Player's Audio Settings in a Fixed Group, perform the following steps:
Android/iOS - Balancing or Adjusting Players in a Fixed Group
- In the BluOS Controller App, select the Players tab . The list of groups/players connected to the BluOS Controller App is displayed.
- Tap the Fixed Group’s context menu (3 dots) and select Audio Settings.
Windows/macOS - Balancing or Adjusting Players in a Fixed Group
- Launch the BluOS Controller app and select the Player Drawer. The list of groups/players connected to the BluOS Controller App is displayed.
- Select the Fixed Group’s context menu (3 dots) and select Audio Settings.
Edit Fixed Group Player's Settings
To edit the Fixed Group's Player Settings, perform the following steps:
Android/iOS - Edit Fixed Group Player's Settings
- Select the Fixed Group’s context menu (3 dots) and select Edit Fixed Group.
- Select the required Player to modify the Player settings.
Windows/macOS - Edit Fixed Group Player's Settings
Deleting a Fixed Group
To delete the Fixed Group, perform the following steps:
Android/iOS - Deleting a Fixed Group
- Select the Fixed Group’s context menu (3 dots) and select Delete Fixed Group.
Windows/macOS - Deleting a Fixed Group
For information on non-fixed standard grouping, refer to our Help Center article.
Note
- Players cannot be added or removed from a Fixed Group. To add or remove players, you should delete and recreate a new Fixed Group.
