Using a Home Theater Group (HTG), you can configure your players to provide Dolby surround sound to your listening space. Refer to our Help Center article for a list of compatible BluOS Players suitable for Home Theater grouping.
Creating a Home Theater Group (HTG)
To create a Home Theater group, perform the following steps:
iOS/Android |
Windows/macOS |
Balancing or Adjusting Players in a Home Theater Group
To adjust the Player's Audio Settings in a Home Theater Group, perform the following steps:
Android/iOS - Balancing or Adjusting Players in a Home Theater Group
. The list of groups/players connected to the BluOS Controller App is displayed.
- Tap the Home Theater Group’s context menu (3 dots) and select Audio Settings.
Windows/macOS - Balancing or Adjusting Players in a Home Theater Group
- Launch the BluOS Controller app and select the Player Drawer. The list of groups/players connected to the BluOS Controller App is displayed.
- Select the Home Theater Group’s context menu (3 dots) and select Audio Settings.
Edit the Home Theater Group Player's Settings
To edit the Home Theater Group's Player Settings, perform the following steps:
Android/iOS - Edit Home Theater Group Player's Settings
- Select the Home Theater Group’s context menu (3 dots) and select Edit Fixed Group.
- Select the required Player to modify the Player settings.
Windows/macOS - Edit Home Theater Group Player's Settings
Deleting a Home Theater Group
To delete the HTG Group, perform the following steps:
Android/iOS - Deleting a Home Theater Group
- Select the Home Theater Group’s context menu (3 dots) and select Delete Fixed Group.
Windows/macOS - Deleting a Home Theater Group
For information on Stereo Pairs and other Fixed groups, refer to our Help Center article.
For information on non-fixed standard grouping, refer to our Help Center article.
Notes
- A Home Theater Group requires a POWERNODE (N331), POWERNODE (N330), PULSE SOUNDBAR (all models), or POWERNODE 2i (with HDMI) as the front channels connected to the TV.
- Stereo Surround will also enable the center channel on the POWERNODE (N331).
- A Home Theater Group requires a POWERNODE (any generation), two PULSE FLEX (any generation), or two PULSE M as the rear channels.
- Only a Home Theater Group can output Dolby content to the rear speakers. For more information, refer to our Help Center article.
- When using POWERNODE models as a rear channel setup, connect the LEFT SPEAKER (+/-) terminal to the room’s left side speaker and vice versa .
- Players cannot be added or removed from a Home Theater Group. To add or remove players, you should delete and recreate a Home Theater Group.
