BluOS Controller app 4.x.x
Moving the party from the Kitchen to the Dining room? Or taking the Living room conversation to the Patio? Use the FollowMe feature so you don't forget to take the Music with you.
Note: To stream Audio to multiple players simultaneously, use the Grouping function.
FollowMe (Transfer Audio)
To seamlessly transfer audio between Bluesound players, perform the following steps:
Note: When using the FollowMe feature, the initial player stops streaming the audio after the transfer.
Android/iOS - FollowMe (Transfer Audio)
and select the Bluesound Player currently playing the audio track.
- Tap the FollowMe
button. The list of available players for transfer is displayed.
- Select the required player to transfer the audio.
To transfer the same audio track to an entirely different player, repeat the FollowMe procedure on the player selected in Step 3.
Windows/macOS - FollowMe (Transfer Audio)
- Launch the BluOS Controller app; select the Player Drawer, and select the Bluesound Player currently playing the audio track.
- Select the FollowMe
BluOS Controller app 3.x.x
BLS-KB16-Y03
Moving the party from the Kitchen to the Dining room? Or taking the Living room conversation to the Patio? Use FollowMe so you don't forget to take the Music with you.
- In the BluOS Controller App, select the Player Drawer
- Select FollowMe
To transfer the same audio track to an entirely different player repeat the FollowMe steps on the player selected in Step3.
When using FollowMe, the initial player stops streaming the audio after the transfer.
To stream in multiple players at the same time, use the Grouping function.
