Bluesound Generation 2 or later players support IR Remote learning.
To program IR Remote learning, perform the following:
- In the BluOS Controller App, on the left Navigation Drawer, select Settings > Player > IR remote > IR Learning. The list of available programmable functions is displayed.
- Select the required function, point an IR remote at the Bluesound player, and press the button to be assigned to perform that function on the remote.
- Checkmark appears next to the function indicating that the IR programming was successful.
The available programmable IR functions* are listed in the table below:
Repeat |
Listening Mode TV |
HDMI / HDMI ARC Input (TV Mode) |
Play |
Shuffle |
Listening Mode Music |
Optical Input (TV Mode) |
Pause |
Previous |
Listening Mode Movie |
Analog Input (TV Mode) |
Play/Pause Toggle |
Next |
Volume Up |
Volume Down |
Mute |
Preset (1-10) |
To clear any remote configuration, perform the following:
- Select the programmed function (with a checkmark).
- Select Clear Code. The checkmark next to the function disappears.
To reset the entire remote function configuration, select Clear All at the bottom of the list.
Notes
- *The available IR functions vary with players.
- IR Remote learning is not possible with Generation 1 Bluesound players due to hardware limitations.
- When using a remote to control the volume on PULSE SOUNDBAR, verify the TV audio setting and disable the built-in speakers of the TV.
- Optical Input (TV Mode) sets the source of the Player to Optical Input and is ideal for programming with the Power button of your TV remote.
- PULSE SOUNDBAR+’s HDMI eARC supports CEC. Controlling attached players with the TV’s remote, may or may not work depending on the HDMI-CEC implementation by the TV manufacturer.
