BLS-KB15-706
To add a song to a saved playlist, locate the desired song from your Library or Music Service and select Add to Playlist... from the Context Menu. To access the Context Menu, press More indicator to the right of the song in Android or iOS, or Right Click/CTRL click in Windows or OS X. You can then select a Playlist to add the song to or you can Create a New Playlist. Songs are added to the bottom of the Playlist.
