BluOS Controller app 4.x.x
Identify BluOS Firmware
To identify the current BluOS firmware version of the Bluesound Player, perform the following steps:
Android/iOS - Identify BluOS Firmware
, and select the required Bluesound Player.
- Tap the Home tab
> Settings button
> About.
The BluOS:x.xx.xx field indicates the current firmware version of the selected Bluesound Player.
Windows/macOS - Identify BluOS Firmware
- In the BluOS Controller App, select the Player Drawer.
- Select the required Player.
- Under the left Navigation Drawer, select Help > About.
Update BluOS Firmware
To upgrade to the latest BluOS firmware:
Android/iOS - Update BluOS Firmware
- Tap the Home tab
> Settings button
> Upgrade. The upgrade screen displays the following options:
- Update available – The Player Notification pop-up menu displays the latest firmware version available for upgrade. Select I want it now to start the upgrade.
- No update available – The player is equipped with the latest BluOS firmware version.
Windows/macOS - Update BluOS Firmware
- Under the left Navigation Drawer, select Help > Upgrade Check - Player. The upgrade screen displays the following options:
BluOS Controller app 3.x.x
BLS-KB15-804
To locate the BluOS Version on your Bluesound Player, select Help, About in the Navigation Drawer of the BluOS App for Android or iOS.
In the BluOS App for Windows or OS X, select BluOS Controller from the pull down menu and select About. This will also display the version number.
