BluOS Controller app 4.x.x
Spotify subscribers can access millions of songs from anywhere in the home using Spotify Connect and Bluesound. It can be easily controlled using the BluOS Controller and Spotify Apps.
All Bluesound Players now support both Spotify Free and Premium accounts. For more information, refer to our Help Center article.
You can visit www.spotify.com to create a Spotify account (premium options available).
Spotify Connect
To Spotify Connect Bluesound Players, perform the following steps:
Note: Ensure that the Spotify App (mobile/computer) is on the same WiFi network as the Bluesound Players.
After establishing Spotify Connect with the desired player, you gain access to a range of limited tasks from the Now Playing screen, including the ability to Play/Pause and skip to the Next/Previous tracks.
- In the Spotify App, play the required audio track.
- Select Spotify Connect and select the required Bluesound Player to play the audio track.
Grouping Bluesound Players
To Group Bluesound Players for multiroom playback of Spotify streams, refer to our Help Center article.
Disconnect Spotify Connect
To disconnect the Bluesound Player from Spotify Connect, perform the following steps:
Android/iOS - Disconnect Spotify Connect
- In the BluOS Controller App, select the Players tab and select the Bluesound Player connected to another Spotify Account.
- Tap the Music tab .
- Under the Music Services section, select Manage > Spotify.
- Tap Logout.
Windows/macOS - Disconnect Spotify Connect
- Launch the BluOS Controller app and select the Player connected to Spotify Connect from the Player Drawer.
- under the left Navigation Drawer, select Music Services > Spotify.
- Select Logout.
Notes
- The Spotify Icon in the Music Services menu of the BluOS Controller App is a shortcut to the Spotify App installation from Spotify.com (Windows/macOS), App Store(iOS), and Google Play (Android).
- Spotify does not require configuration in the BluOS Controller App.
- Android/iOS: A Spotify Icon appears in the Music Tab > Music Services section when any Bluesound Player has been used as a Spotify Connect device. Selecting this icon resumes the currently paused stream or playlist in the connected Spotify account.
- Windows/macOS: A Spotify Icon appears in the Navigation Drawer of any Bluesound Player that has been used as a Spotify Connect device. Selecting this icon resumes the currently paused stream or playlist in the connected Spotify account.
BluOS Controller app 3.x.x
BLS-KB14-Z04
Note: The BluOS Interface swap feature (BluOS 3.x.x to/from BluOS 4.x.x) will be discontinued with the release of the latest BluOS firmware in mid-Spring 2024.
Spotify subscribers can access millions of songs from anywhere in the home using Spotify Connect and Bluesound Players. It can be easily controlled using the BluOS Controller and Spotify Apps.
All Bluesound Players now support both Spotify Free and Premium accounts. For more information refer to our Help Center article.
Note: Ensure that the Spotify App (mobile/computer) is on the same Wi-Fi network as the Bluesound Players.
Notes
- Spotify does not require configuration in BluOS Controller App.
- A Spotify Icon appears in the Navigation Drawer of any Bluesound Player that has been used as a Spotify Connect device. Selecting this icon resumes the currently paused stream or playlist in the connected Spotify account.
