BLS-KB14-501
When connecting to a radio station in Bluesound using TuneIn, the highest quality stream with a reliable connection is automatically selected for you.
For stations that provide different quality streams, you can choose between the available streams using the BluOS App. While listening to a TuneIn Stream, open the context menu (3 dots) and choose Select Stream.
Note
- Some stations may restrict their higher quality stations or premium subscriber stations to a URL that will have to be entered manually with Bluesound. See the following article for details about saving a URL entry for radio stations: BLS-KB16-314
