BLS-KB14-304
Bluesound players’ volume can be adjusted using any of the following options:
Volume Slider in BluOS Controller App
The volume slider for the selected player is available in the Now Playing screen of the BluOS Controller App.
- Android/iOS – Available at the bottom of the Now Playing screen.
- Windows/macOS – Click the volume icon in the lower-right corner of the BluOS Controller App to adjust the volume slider.
Alternatively, the volume of players can be adjusted from the Player Drawer of the BluOS Controller App.
Tablet or Phone physical volume buttons
You can use the physical volume buttons of any iOS (AirPlay mode only) or Android device to adjust the volume of the selected player when the BluOS Controller App is running in the background.
For Android devices, each press of the physical volume buttons adjusts the current volume by 2 dB*.
Tapping (+) and (-) next to the volume slider
In the BluOS controller App, the plus and minus buttons adjacent to the volume slider of the Now Playing screen of Android/iOS devices can also be used to adjust the current volume by 2dB*.
Player's Hardware Buttons
Tapping/Pressing the (+) or (-) button on the Bluesound Player changes the volume by 1 dB*. Press and hold the buttons for larger changes.
The NODE ICON / NODE (N132) / NODE X / NODE (N130), and POWERNODE (N330) have touch control volume sliders with proximity sensing.
Generation 1 - NODE (N100) and VAULT do not have physical volume control buttons.
Note:
*When Volume limits (dB) are set at -90dB and 0 dB.
