Logitech Harmony Ultimate (hub) and IR Learning NAD C700
BeantwortetI want to able to control my NAD C700 with my Logitech Harmony Ultimate (hub). The NAD C700 is not (yet) in the Harmony database.
First option:
This option does not seem to work. I'm able to add the NAD M12, but after that I'm stuck, don't know that to do or how to do it, and I can't find detailed steps what to do exactly. In the end, the NAD C700 does not respond to my Harmony.
Second option:
I'm not able to learn the IR codes to my Harmony; when I'm instructed to press a button on the remote (e.g. volume up), when I press it, nothing happens, so the instruction is not learned.
Third option:
- The Bluesound remote control (RC1). I doesn't come with the NAD C700 by default. It also hasn't got the option to select inputs, so I don't want it.
Fourth option:
- Contact Logitech support to add the NAD C700. I did that. They can do it when they have the Hex / Pronto codes, so I've requested these from NAD. No response, yet, after a few days.
Any help is appreciated!
Hi Ronald - please contact support@nadelectronics.com regarding your NAD C700
