issues connecting nad t758v3 to wifi
18 Kommentare
    Hello Tom,
    The hotspot should appear once you do the Factory Reset, and will show up as IP Address "10.1.2.3" under the System Info of your T758v3.
    However if it does not, it may be faster to use an Ethernet connection temporarily so you may fill in your WiFi details. I will have steps below:
    1) Disconnect the power from your T758
    2) Connect an Ethernet cable directly to the receiver, which goes directly to your router
    3) Connect the power back into the receiver
    4) Wait until the T758 powers up
    5) Open the mobile BluOS controller while connected to the WiFi network of your home
    6) Select the 3 lines in the top left corner of the BluOS app and go to Settings
    7) Select Player and then WiFi
    8) Select the WiFi network you wish to connect to and enter the password for it
    9) Wait 5 minutes and then disconnect the power from your T758
    10) Disconnect the Ethernet cable and then reconnect the power
  • Tom Vandermaesen
    First of all the receiver doesnt have an ethernet port.
    The nad receiver who is reported with stickers to be a legit bluos player, has a usb hub with a bluetooth and wifi adapter attached to it.
    You say connect to that ip address. But this will never work if im not connected to the hotspot. And i just did the complete factory reset succesfully ( all my settings are gone ) and i was waiting with my phone next to it to see its wifi hot spot. Nothing....
    I can open up the bluos controller app on android but this will never work if the NADis not connected to the wifi....
    So im lost here.. and very sad....
    You will mostlikely send me to nad support now ...
  • Jeppe Kirkegaard
    I'm having the exact same problem. Everything else is working fine on my wifi.
    -1
  • Augustin Safdi
    Jeppe, i have solved the problem by changing the frequency of the channels from the router.
    Log in to your router,then go to wifi and change the channel.
  • Tom Vandermaesen
    Jeppe,
    I did one simple thing that fixed all the issues imediatly......
    I changed the usb hub to another one, and plugged in everything. It worked from then  instantly.
    I also bought a cheap usb to utp converter to have a wired connection.
    I spent like a year on this ....
  • Augustin Safdi
    Tom, heb jij die USB/ethernet met een 2.0 USB aangesloten?
    Ik had t met een 3.0 USB geprobeerd maar lukte niet.
    Wat heb jij prc gedaan?
  • Jeppe Kirkegaard
    Thanks for the input!
    Augustin Safdi which wifi channel did you choose?
    Tom Vandermaesen I have also been considering that the cause might be in the USB hub that came with my T758. Are you using an USB 2.0 or 3.0 hub?
  • Augustin Safdi
    Hi Jeppe, most of the time i pick channel 3 or 4.
    When you do this,check your wifi speed and strenght of the signal.
    When its green its more then fine.
    You can check that in the Bluos app at the diagnostic.
  • Augustin Safdi
    This is all about the router.
    Before i had this new router,ibhad never had problems with signal or channels.
    So every new router can give some problems.
    But then again,you Just have to look what router settings you have.
    So the problems about taking out of the power and back is a known problem with the NAD Bluos.
    It's all about getting the right settings on your router.
    I hear some things like wiring a USB to an ethernet converter but only with a 2.0 USB.
    I tried it with a 3.0 USB but no succes.
    But when i found out that you Just have to change the channels in your router, i dont have issues no more.
  • Jeppe Kirkegaard
    Hi Augustin,
    Changing the WiFi channel actually did the job - thank you so much! I can't believe I spent months fixing the issue and the fix was so simple :)
    /Jeppe
  • Augustin Safdi
    Hi Jeppe,
    Im glad that you have fixed it.
    Enjoy!
  • Tom Vandermaesen
    i think it was a 2.0 hub but im not sure, its a very cheap one from green.... somthing
  • Tom Vandermaesen
    usb 3.0 hub from anker and utp to usb from syncwire
  • Dave Chawner
    Hi Tom,
    I have just tried to get an ethernet connection to our NAD T758v3 to work but failed!
    Was any specific setup required or was it just "plug and play"? Were there any specific settings required at the router? Did the WiFi adapter need to be removed from the NAD USB hub first? Was it necessary to use a USB hub?
    There doesn't seem to be any setting in the NAD to choose WiFi or ethernet connection.
    I'm using a TrippLite ethernet/USB adapter.....could you confirm the exact model adapter you used?
    Could you please let me have any advice you can offer, any tricks I might have missed!
    Thanks.
  • Augustin Safdi
    Hi Dave,
    Connexxion via cable does not work.
    Just use wifi and check your router settings.
    Just Read it in this topic.
  • Dave Chawner
    Hi Augustin,
    Thanks for your comments.....I have read elsewhere that the ethernet cable connection via an USB adapter will work! The WiFi does sort of work but has proved to be not totally reliable and I'm investigating alternative network connection options. The issue may be which chipset driver the BluOS uses for the ethernet/USB adapter. It seems the ASIX chipset may be the only one supported. I've now discovered the TrippLite adapter uses a Realtek chipset.
    USB to ethernet adapter on NAD T758 v3 - Discussion (bluesound.com)
  • Jose
    Hola!
    Llevo 2 años con exactamente el mismo problema. Conectar el T758v3 con mi iPhone es prácticamente una cuestión de suerte. DESESPERANTE. Mucho amplificador pero una tecnología de conexión NEFASTA.
    Tras muchísimos problemas de conexión, decidí acudir al servicio técnico. Me dijeron que fallaba el adaptador de USB y me lo cambiaron. El resultado es exactamente el mismo desde el primer momento que conectas el adaptador. Se conecta en el minuto 1 y en el minuto 2 ya está desconectado de nuevo. Un horror!!!
    Cambiando el canal de mi router, conseguí estabilizar el problema, pero bajé considerablemente el rendimiento de mi conexión por lo que no me parece una solución adecuada.
    La solución ha sido comprar el adaptador de USB a RJ45 (Ugreen 2.0 con chipset ASIX) - 12€ en Amazon) que comentaban los otros compañeros. Sacar de la caja, conectar el cable ethernet y listo!! Ahora la conexión es perfecta, no hay cortes y la app encuentra SIEMPRE al T758v3.
    Realmente estoy más que satisfecho con mi compra del adaptador: tengo el amplificador que esperaba tener cuando lo compré!!! pero triste por que resulte tan complicado conectar por wifi un amplificador tan maravilloso como es el NAD T758v3.
    (versión inglés con Google Translator)
    Hello!
    I have been with exactly the same problem for 2 years. Connecting the T758v3 with my iPhone is practically a matter of luck. MADDENING. Much amplifier but a HORRIBLE connection technology.
    After many connection problems, I decided to go to the technical service. They told me that the USB adapter was faulty and they replaced it. The result is exactly the same from the first moment you connect the adapter. It connects in minute 1 and in minute 2 it is already disconnected again. An horror!!!
    By changing the channel of my router, I managed to stabilize the problem, but I considerably lowered the performance of my connection, so it does not seem like a suitable solution.
    The solution has been to buy the USB to RJ45 adapter (Ugreen 2.0 with ASIX chipset) - € 12 in Amazon) that the other colleagues commented. Unbox, connect the ethernet cable and voila! Now the connection is perfect, there are no cuts and the app ALWAYS finds the T758v3.
    I am really more than satisfied with my purchase of the adapter: I have the amplifier that I expected to have when I bought it !!! but sad because it is so difficult to connect such a wonderful amplifier as the NAD T758v3 via Wi-Fi.
  • Dave Chawner
    Hola Jose, did you read this post?
    NAD T758 V3i ethernet network connection – The Bluesound Support Crew
    Pleased to hear the same solution worked for you!
