My powernode losses connection when playing vinyl
BeantwortetMy powernode always looses network connection when I play vinyl records and I have to reset the unit for it to pick it up again. The biggest problem this causes is that I can't adjust the volume from the app.
Hi Jonas,
Please submit a support request using the BluOS app. This way, our app will automatically send us a log file that our support crew can analyze to help diagnose the issue you are experiencing.
Using the desktop BluOS controller app, BluOS >> Help >> Send Support Request.
Using the mobile BluOS controller app, BluOS >> Settings >> Help & Support | Send Support Request.
