some wifi problems with powernode 2i
WIFI connection with powernode 2i.
1. how can i check which WIFI network is connecting with powernode 2i now?
the LED is blue. and at the BluO, there's no list of available WIFI network.
but there's some WIFI networks in that area.
2. Does powernode 2i support 5G WIFI network? or only for 2G?
i think i miss click 5G when i set the BluOS at first time.
3. plz teach me how to connect WIFI manually.
when i try with BluOS, i typed SSID and Password and click "update."
it was connecting for 1-2min. and nothing happen.
1.) Help - Diagnostics will show signal strength, and the network you are connected to.
2.) 2i's support both 2.4GHz and 5GHz
3.) https://support1.bluesound.com/hc/en-us/articles/200284458-How-do-I-connect-my-Bluesound-Player-to-the-network-
