Connecting both bluetooth and cabled speakers
AnsweredI have my Vault 2 connected to my speakers via an amp but am looking to also have a portable Bluos speaker for when I move around the house. Can this be done and, if so, how do you switch between the two? I have scanned questions but cannot see this there so any help much appreciated.
Many thanks
Portable speakers will use ethernet or wi-fi.
All speakers will appear in the player drawer. Could be used as single players or grouped. Can be controlled by more than one BluOS Controller.
https://support1.bluesound.com/hc/en-us/sections/200065316-Grouping-and-Playback -
Thanks Bjørn, big help
Hey, Tony (and Bjorn!),
Sounds like you had a similar situation, but wanted to make sure it worked. I want to run my stereo in my living room with my wired speakers and use a remote wireless speaker but have them all play the same music input from BluOS in sync.
I have a Yamaha AVR but apparently the Musiccast 20 isn't compatible. Just trying to add a speaker outdoors to the pool area.
Thanks!0 -
Sorry Sean, have not got round to doing it yet. Covid then my Vault ceasing and a 2 month wait for parts means I have left it for now. I did speak to the shop where I bought it and they say it is not an issue and yo can have all speakers going or just the Cabled or Wireless. They agreed wit Bjorn and said the interface can control it.
Good Luck.
Appreciate it. Just got over my second covid bout. Good times.
I may just order it and try it out!0
5 comments
