Node 2i RCA Output Specs
AnsweredHi
Can anyone tell me what the specs are of the RCA L+R outputs?
I have my late father's Quad 44\405-2 and using the tape loop on the 44, it has the ability to adjust its inputs to match the source via a series of dip switches. The 44 is also currently in for a much needed service and as such we can also update the tape module 'internals' for a closer match if the dip switches do not give enough flexibility.
Many thanks
Chris
Many thanks Bjorn, I clearly wasn't using the right search terms :-)
Cheers
Chris
"impedance" is the word :-)
I believe 2.xV is the right answer for the (fixed) output voltage.0
