    Avatar
    The Output Impedance of the Node 2i is 650 ohms (and the Output Voltage would be 3/5 volts (=0.6V)).
    Comment actions Permalink
  • Avatar
    fafa44
    Hi,
    The fixed output voltage is not 2,1V rms?
