Node2i and Project Pre Box S2 Digital DAC
    Avatar
    Wesley P.
    Hello Steve,
    After viewing the FAQ on the product page of the Project Pre Box S2, it appears that it only supports MQA content through the USB input.
    "In order to enable MQA playback via S/PDIF a hardware change would be necessary, this would cause the price to go much higher. MQA hardware decoding is only possible via the asynchronuous USB input of Pre Box S2 Digital."
    Since the Node 2i does not have a USB output, you will not be able to use the Node 2i with this external DAC to render your MQA content.
    Wesley P.
    Comment actions Permalink
  • Avatar
    Steve Pomichowski
    Thanks for your prompt response Wesley. I understand . I appreciate your help in finding that on the Project FAQ page.
