Disconnecting problem between pulse sub and pulse soundbar 2i
AnsweredThe subwoofer keeps losing contact with the pulse soundbar 2i. Even when the soundbar and the subwoofer are playing mid film. I don't know what to do anymore, because this is a constant trouble and I've tried almost anything.
(I've tried making contact between the sub and soundbar again and again even when the film is playing)
Is my soundbar broken? or is this a known problem? or is it something completely different?
Hi Rivka
I am escalating your issue to our Support Crew so they can confirm some things. They will be in touch...
Hi,
I have the exact same problem and I have tried different network setups with the same result.
The sub keeps disconnecting. Very frustrating.
Hi Jorgen
The above issue was resolved by a software update. Please select Help, About and ensure your SOUNDBAR is on BluOS 3.2.13 or higher. If it IS, please select Help, Send Support Request so we may review the log file.
Hi Tony. Thank you for your quick reply. Unfortunately I have the latest software version and it stilk disconnects. I'll send you a support request.
Best regards
Something new on this post? I have similar problem my Pulse 2i soundbar and a subwoofer with Bluesound RT100 wireless speaker link. Latest software and all that, but every time I use my soundbar I have to start with pairing the subwoofer and soundbar
Regards
@Sigfus: Support has been good at replying quickly, but we ended up returning the sub and soundbar to the place of purchase, whom are now testing it (or perhaps sent it to Bluesound). I'll try to make an update here once we get the soundbar/sub back. Best regards.
Edit below:
I got this note from support, but only after returning the sub/soundbar so we never got to test it. Perhaps you can try it: "Can you confirm on the Soundbar if you turn Amplifier Standby, under Settings > Player to OFF - does the same issue occur? This is done via the BluOS app."
Thanks Jorgen for the tip. It helped a little bit. With Amplified Standby set to OFF my Subwoofer does not disconnect from my Soundbar when it goes to Standby. How ever it takes a while for the Subwoofer to be active again when the Soundbar start again...maybe couple of minutes.
With Amplifier Standby OFF I cant do anything than wait couple of minutes after it become active again
With Amplifier Standby ON I can pair again right after the soundbar start up.
I wrote to Bluesound Support last Sunday and haven´t received any reply :-(
Hi Sigfus
Sorry about that - we have been in extremely high demand with the success of Gen 2i and AirPlay.
You do raise a good point; https://support1.bluesound.com/hc/en-us/articles/115000168948
Pairing with a PULSE SOUNDBAR
- Ensure the PULSE SOUNDBAR is on and connected to the network
- Play something through the PULSE SOUNDBAR to make sure the Player is not in Standby Mode
- Ensure the PULSE SUB is plugged in and powered ON
- Note the location of the small Pairing Button on the back of the PULSE SUB
- In the BluOS App, select the PULSE SOUNDBAR from the Rooms Drawer and press the Settings icon
- Scroll to the bottom and press Pair with Pulse Sub
- Press and hold the PAIRING button on the rear of the PULSE SUB for ten seconds then release the button - the front LED will blink green.
- The Pair with Pulse Sub status in the App will change to Pairing and then Connected
- The PULSE SUB LED will then again go out after 15 seconds
I don't know if someone is still having issues but I've had something similar. My pulse Sub was disconnecting over and over again (I had to link the sub every 1 or 2 minutes again to the Pulse Soundbar 2i) while listening to music (Spotify). So I tried a couple of things and everything is working fine now for a couple of days.
With the following settings I didn't have the problem anymore:
- Sub switch is set to on (not auto or off)
- Pulse Soundbar 2i Amplifier standby is set to Off
- Pulse Soundbar 2i is connected wired to my network.
- Then I assigned to the Pulse Soundbar 2i a static IP-lease via my router (Ubiquity Amplifi). So it keeps having the same IP-address. (I've tried this because in the past I had some issues with my network printer, which couldn't be found on other network devices like laptops and smart phones.)
- Unlink the subwoofer from the Pulse 2i Soundbar
- Pairing the subwoofer again to the Pulse 2i Soundbar as you have done by first use.
It worked for me, so maybe this can be the solution for more people having this kind of issues.1 -
Thanks for the tip Eelco
I have the same problem, how can I resolve it?
Hi Glenior
If you are having problems, please select Help, Send Support Request so we may see the log file form the SOUNDBAR
Hi everyone!
I recently bought a Pulse soundbar 2i and the compatible sub. I'm surprised to see that the same issue keeps occurring after 5 years. After successfully pairing the sub to the soundbar, it disconnects after roughly 5 minutes. I've updated my firmware and even bought a WiFi extender to strengthen the signal. Nothing works. I desperately ask for advice from those who found a solution to this frustrating issue.
If you are having problems, please select Settings, Send Support Request so we may see the log file form the SOUNDBAR
14 comments
