Powernode N330 (2024) wifi issues
14 comments
    Permanently deleted user
    Just some observations…
    Your Router should be switching to a non DFS frequency when it detects Radar, equally you should, be able to manually select a non DFS channel for 5Ghz rather than letting the Router decide.
    The Fritz!Box range of Routers (common in Germany) can detect DFS channels when you turn on Wi-Fi on the Router and then it won’t subsequently use them.
  • Thomas
    Unfortunately, the powernode immediately switches to the stronger 5GHz because the access data is identical. i cannot force it into the 2.4Ghz band. I can only hope that it might be possible to restrict the band in BluOS. I'm not going to switch off the dual band for the Powernode here at home. The solution with the TP Link Bridge on the Ethernet port solves the problem as the bridge only handles 2.4GHz and the Lan port of the Powernode is always prioritized. But is that what I want? an extra 20EUR device connected to a 1000EUR hi-fi device to make it work? doesn't fit together for me.
  • Thomas
    Vonets VAP11AC - By the way, this is a very reliable and high-performance dual-band bridge 2.4 and 5Ghz
  • Thomas
    i use unifi access points for providing wifi network - with fritzbox 7490 and 7590 the 5GHz and wifi 5 protocol always had problems- the whole wifi 5 was paused for up to 10minutes. the fritzbox event logs explain it to me. again. i did not have any issues with other wifi devices. again - i can reproduce the non working band switching
  • Permanently deleted user
    So you have Wi-Fi running on the Fritzbox devices and the Unifi WAPs?
  • Thomas
    no. i had replaced any fritzbox model with unifi APs for WiFi, Gateway ( DreamMachine Pro) for routing etc, and a seperate vigor dsl modem for connection to isp
    Just manually select the channels in Unifi, auto is cranky at best.
    I live close to a major airport and have both aircraft and weather radar here, when DFS gets detected all the Routers locally start hunting down a new Chanel and they themselves clash.
  • Thomas
    No. I'm not going to do that. The Powernode supports two frequency bands. However, if there is an interruption in the 5Ghz band, which can happen, the Powernode will stop working completely. I don't accept that as a solution.
    Furthermore, I can also force the 5GHz exit by using Airplay. After 10-15 minutes Airplay stops, the power node is still on but it has switched off.
    logged out of the wifi. Honestly, in other articles it is repeatedly pointed out that the Powernode is an allways on streaming device and therefore has no on/off switch. But if there are problems with the WLAN, all other components are always to blame and you should unplug the Powernode. I fear that the lack of willingness to investigate the faults in the Powernode leads to an overall bad reputation for Bluesound. I also see it in other posts and I'm beginning to regret the purchase. The issue has been dragging on forever. And no, I'm not the first. If you summarize the WLAN problems, they are all very similar and at some point you should recognize that it is not 1000 people who are wrong but one.
    I am just another user who has DFS issues so why attack me?
  • Thomas
    sorry. it's not your fault. i've already invested hours doubting myself. i'm trying to make all problems reproducible. and i'm also trying to find all solutions. I'm just starting to see that it's a fight against windmills. I sincerely apologize to you if I have attacked you personally. That was not my intention.
  • Mateusz Wrzos
    Any update here? Has the issue been addressed?
    Had the same problem, buying the TP-Link adapter running on 2.4GHZ and connecting the Powernode via ethernet solved the issue, but it's a workaround rather than a real solution.
  • Mark T.
    Sr. Support Crew Member
    Hi Mateusz,
    I have escalated your feedback to a support request. A member of our support crew will reach out to you soon.
  • Mark P
    Same behaviour here, and I can rule out DFS as the cause.
    POWERNODE, BluOS 4.16.6, FRITZ!Box 5490. The unit drops its Wi-Fi association at random and never re-associates. Only a power cycle brings it back. When connected it sits 2 metres from the router at 433/433 Mbit/s with full signal.
    What I have already eliminated: 5 GHz fixed to channel 40 (non-DFS), 2.4 GHz disabled entirely, static IP reserved, no Wi-Fi schedule, nearby electronics powered off, router firmware current, no BluOS update available.
    So this is not radar and it is not range. The POWERNODE simply drops the association and does not attempt to reconnect. That is a firmware defect.
    Bluesound: an ethernet bridge is a workaround, not an answer, on a device at this price. Please confirm whether this is a known issue and whether a fix is in progress. Ticket submitted with logs via the app.
  • Max
    Greetings from Germany!
    My Product: Powernode N330
    I ran in the same issue!
    100% an the same boat with Mark P and Thomas and Mateusz etc.!
    Last weekend the product could not connect with WLAN. I sent a support request and the answer was the standard Wifi-connect procedure which of course I did multiple times BEFORE.
    The Powernode always falls back the the wired connection / 5G  - seems almost that it does not correctly connect with the WLAN after submitting WLAN password etc. and updating: I selected 2.4 GHz instead of 5G just to make sure, but if I checked again: I falls back to 5G (or maybe even the wired connection.
    I assume that some bug sneaked in the firmware after last update. Had no issues at all since I got that unit (couple years now).
    Looking forward and hoping that Bluesound will escalate this issue and will fix it via firmware update.
