Optical link connection
AnsweredI connected my Vault 2 to a pair of KEF LSX II speakers via an optical cable, but when, on the speakers, I select Optical as the source, I am met with silence. I think the cable is ok as I can see the red light at the terminal. Is there a setting I need to change on the Vault or the speakers? Should I try connecting via an RCA cable?
Perhaps this extensive guide can help?
https://support1.bluesound.com/hc/en-us/articles/15341217270679-How-do-I-manage-the-Audio-Settings-on-my-Bluesound-player
First to check, output settings for the Vault (i.e. whether it's set to fixed or variable [although variable is not explained in guide]).
Second to check, volume level on the Kefs. -
Thank you very much, KriHad, that was the answer. My KEF speakers and Bluesound Vault 2 are now working happily together via the Optical connection.
2
