NODE X HDMI out and COAX out
AnsweredCan I connect the Node X HDMI out to my TV and at same time have the Node X Coax out connected to my (digital) amplifier?
And if I can, will my amplifier be receiving the highest possible audio signal from the Node X ?
Hi Keith,
Just a quick heads-up: the HDMI on the NODE X is actually an input, not an output.But no worries! Here's a setup that should work perfectly for you:
- Connect your TV's HDMI eARC to the NODE X.
- Then, use the COAX out to link to your Amplifier
If you run into any more issues or need further assistance, feel free to email us at support@bluesound.com.
Thanks for #LivingHiFi
