Node X with external DAC: Nothing switches off. Node is constantly on!
AnsweredHi.
I'm using a Node X with the Topping E30 II DAC. I'm satisfied with the result in audio quality and love the combination of the Node X with an external DAC.
I am having one big issue though:
The Node X doesn't switch off at all. Not even after 15 Minutes. The DAC things, it's still receiving signal from the DAC and also doesn't go into standby.
When I use Vacation Mode (Long-press the blue button on top of the Node X) the DAC switches off completely after losing signal.
How can I tell the Node to switch off after 15 minutes of idling? It doesn't go into a standby state at all.
Thanks
Irritatingly the digital outputs of all variants of the Node are always 'on' - even when in standby/sleep mode. The outputs are only disabled if either Vacation Mode is invoked or the Node is powered down.
Meaning that the DAC will never Auto-power itself off, because it's always "receiving" signal, right?
There is absolutely no solution to this?
Correct. We've been waiting years for this 'feature' to be fixed...
2 -
It is annoying this and the explanations that seem to come from Bluesound don’t add up. You would think it would not be a hard fix.
4 comments
