Is It Feasible to Hack Together a Quad System?
    It would be roughly the same price, maybe cheaper given the cost of other parts and would be way less of a hassle and far more reliable to simply buy a SOUNDBAR and 2 FLEXes rather than the solution you are suggesting which may or may not work.
  • Seppi Evans
    I would look for an alternative solution as this would be costly to try and most importantly the two sets of Flex’s playing stereo would not be in sync as you have two stereo outputs. Bluesound can of course sync multiple devices but from a single stereo stream.
Post is closed for comments.
