Powernode clicking and cutting out
I have a brand new powernode bought in November. After 10-15 minutes, it starts clicking with the sound cutting in and out.
Input is from the optical out of my TV. It happens with Spotify as well.
Hi Vadim
Replace the optical cable with a new one.
If problems persist, please select Help, Send Support Request. If you do send a support request, please let us know the make and model of the television.
Is the Powernode clicking or is the sound coming from the speakers?
I had a similar problem. My Node would stream from Amazon Music faultlessly. However, when switching on the Node and using the TV optical output I would hear subtle digital clicking from the speakers.
I found that if I briefly streamed from Amazon or radio then switch back to optical input, that would resolve it.
I haven't had the issue for several months, so assumed an update fixed it.0
