Audio stream lag /delay
BeantwortetHello,
I have following set up : node2(2021) wired connected and 4 flex speakers WiFi connected
1 is used as stand alone (as radio clock) , no problem with this one
other 3 are grouped but are playing with a lag of 5 to 7 minutes, iow i listen to the news from 7,00u at 7,05u or 7,07u. When you select a radio station its ok for some time but then the lags begin to increase (from 1 min to 7 min)
i am using tuneln for radio listening
Please check WiFi strength on your Bluesound Players. Make sure that none of the players have a wifi strength of -60 and above. To learn more - What should my Wireless Signal Strength be for best performance? – The Bluesound Support Crew
If all your players have great wifi signals and still having issues. Please send us a support ticket using the BluOS app, this way we can review the diagnostic logs on your players. Using the BluOS APP, BluOS >> HELP >> Send Support Request -
One has -42 (close next 1 AP) others have between -56 / - 58
