Red light on updating
Easy fix..if your node 2i is stuck on latest update its very easy to fix. Hard wire to your network. Delete blueos app and reinstall. Node will go through upgrade process..i also had a usb with latest firmware installed but not certain if necessary. Should take less than a min to upgrade.
I love my 2i
0 Kommentare
