Cross Over range on Sub-woofer
    Bjørn Ulvik
    Sub out is always active.
    Variable 40-200Hz with subwoofer setting ON. That will also filter the speaker output.
    Earlier firmware had, when subwoofer setting OFF, a fixed 80Hz filter, and full range speaker output.
    Not sure about the latest firmware.
  • ALI NAQVI
    Thank you.
