Initial Vault setup: No wifi detected
BeantwortetI have followed the setup instructions. The ethernet cable is plugged in and tested for connectivity. The little light is blue. Yet I see no wifi network associated with the Vault on my iPhone, or on my laptop
The internet seems to think I might need to adjust router settings?
I have no idea which ones might need adjustment...
I'm following the install instructions. It says to look for the hotspot in the wifi settings of my phone. I can connect via Bluetooth, but that's not what the instructions say on my phone, nor does it get me past the opening setup screen on the app itself. I can't click the home button, settings...nothing. My phone does not know I have a Vault.
Any thoughts?
Thanks for those ideas. But I think it must be router settings, then, because the desktop app is having no luck, and Local Network is enabled on the phone...
Seppi: The new cable was the key. Thanks a lot!
