Google Wifi - Players keeps connecting to wrong connection point
Hi,
I have 3 Flex, 1 Mini and 1 Power Node. The three Flex and the Mini constantly connects to the wifi "puck" that is the farthest away with thus connecting to the wifi with a bad connection.
Is there a way to force the players to connect to the closest one, or any other best practices? Often the sound stops very often and this is very annoying.
Br,
Gaute
A client can/should never be forced to connet to a dedicated access point.
You can adjust/lower the output on the access point they connect to.
As a reference, if you have combined SSID, 2.4GHz should be at least 7dB lower than 5GHz band.0
