Not possible to connect node2 to wifi
BeantwortetHave the following problem with my node 2:
-instant solid red LED
-no boot sequence
-reset button no effect
-not discoverable
-status LED near Ethernet blinks independently of cable connection.
What can I do to solve the problem?
Rgds
Herman
You could try a factory reset (there is no such reset button but a sequence) but with the red led best best would be to contact support support@bluesound.com
Same here. Did you get any useful help from support? I didn't. Very disappointed
No the machine was broken, probably needed reprogramming. I sent it back to the vendor.
