Stereo Playback Unusable Due to Severe Sync Issues (2x stereo Pulse M, Qobuz, Wifi, Wired)
5 Kommentare
    Permanently deleted user
    You need to use the BluOS App immediately after you loose sync to log a support ticket, this will then automatically send the log files to Bluesound for further investigation.
  • Kars Veling
    I would like to escalate this issue, as additional testing has now conclusively ruled out the network as a contributing factor.
    I connected both Pulse M speakers directly to the ISP router, completely bypassing the TP-Link Deco system (no mesh, no routing, no filtering). I also used the router’s own WiFi for control, ensuring that both the speakers and the control device were on the same local network.
    Despite this full network bypass, the issue persists exactly as before:
    • The first track of an album plays in perfect sync.
    • When the next track starts automatically, a severe left/right sync delay occurs (up to ~1 second).
    • Manually skipping to the next track immediately restores correct sync.
    • The issue then returns again on the following automatic track transition.
    • Internet radio playback remains perfectly synchronized at all times.
    Given that:
    • The problem occurs on both wired and wireless connections,
    • Persists after completely bypassing the Deco router and mesh,
    • Occurs with both Qobuz Connect and direct BluOS playback,
    • Is isolated to automatic track transitions in stereo mode,
    this strongly points to an issue in BluOS stereo synchronization / clock re-alignment on Pulse M stereo pairs during track transitions, rather than a network-related problem.
    Could this ticket please be escalated to engineering for investigation? I am happy to provide logs, timestamps of affected transitions, firmware versions, or perform any additional diagnostic tests you may require.
    Thank you for taking this further.
  • Mark T.
    Sr. Support Crew Member
    Hi Kars,
    I have escalated your feedback to a support request. A member of our support crew will reach out to you soon.
  • Peter Moors
    This defect seems very similar to the one I reported here: Support Request #504635. For that request I only got a workaround, and the defect still appears. Hopefully now it will be solved.
  • Dennis Bogaard
    Is there any news on this issue? I am having similar issues. My setup is two mini 2i as a stereo pair and a pulse sub. Th proble isn't always there: we can listen for days without synchronising issues. Then suddenly, I have to reboot the whole system 4-5 times before everything is ok. It happens with Qobuz, Tunein radio and with my personal audio files on a NAS.
    Very curious what might solve the problem.
