Trouble with BlueSound on Subnet
5 Kommentare
    Mark T.
    Sr. Support Crew Member
    Hi Peter,
    I see that you have submitted a support request to us regarding this. It looks like you have quite a complicated network. See if these kb articles will help you with your networking issue.
    https://support.bluesoundprofessional.com/hc/en-us/articles/360052825254-How-Do-I-set-a-Static-IP-Address-on-my-Player
    https://support.bluesoundprofessional.com/hc/en-us/articles/360060411413-How-to-Discover-and-Control-Players-from-a-Remote-Subnet-
  • Alain DW
    Lossless
    I'm not a specialist in networking, but I had a little project to run a Node2 and a Node2i on separate subnets. This works very well and every Node was able to connect to the internet and a NAS on subset A, but the problem was the communication with a controllerapp on subnet A to control a Node on subset B. Apparantly you need to have a router with vxlan support, which is not common in consumer hardware. Maybe an avenue to explore?
  • Peter Decker
    Thanks for answering so quickly.
    Actually, meanwhile I did some research and figured out I am not the only customer experiencing difficulties.
    Here a response form Claude.ai:
    Sonos mDNS ✅ Ja Modern
    Denon HEOS mDNS ✅ Ja Modern
    Yamaha mDNS ✅ Ja Modern
    Bluesound LSDP (UDP) ❌ Nein Legacy
    Bluesound developed this technology 15 years back and since did not modernize.
    Thus, not working with subnets / on different VLANs.
  • Peter Decker
    Would be great if Lynbrook could release a new bluesound app that uses commonly used standards. Meanwhile I have to live with the restriction. Thanks.
  • Alain DW
    Lossless
    If I remember well, Bluesound also uses mDNS and the communication problem had to do with mDNS not been piped through the subnets, hence the need for vxlan. But feel free to correct me if I'm mistaken.
