NAD M10 Ethernet Problems After Update
    Hello Bryan,
    If your other Bluesound players work fine over Ethernet and your M10 works correctly on WiFi, I wonder if there was an internal update made to your switch that could be interfering with either Roon's protocols or Bluesound's.
    You could try two things:
    - Test the M10 with Roon while bypassing the switch (temporarily directly ethernet connect to the router)
    - Test the M10 connected to the switch and controlled with the BluOS app
    To help narrow down the issue.
  • Bryan Allen
    The switch didn't get "auto updated" it's a Cisco managed switch that requires I log into smartnet and manually download any FW updates. That and two of my other Bluesound devices (a node 2, and a powernode 2) are both connected to that same switch via ethernet -- and so is my dCS Rossini. It's just so very odd. I also tried streaming directly from the Bluesound app (Tidal and Qobuz - both 16 and 24 bit had the same result - it would play for a few seconds then stop).
  • Hari
    I have the exact symptoms but on a NAD C658 since the last firmware update.
    Did you manage to fix this issue?
