Sound bar not completing installation
4 Kommentare
    Hello Richard,
    I suppose since it's up on a bracket it may be difficult to run an Ethernet cable temporarily from the Soundbar to your router so it may complete the upgrade/setup process?
    If possible, try that; in the meantime, I've escalated your case so that a member of our support crew may look into this further.
  • richardwebster581
    Thanks Sam,  Unfortunately I can't connect direct unless I take off the bracket and also the power is via a spur and I don't have a spare cable.   I look forward to hearing from the support crew as it is very frustrating.   Thanks,  Richard
  • richardwebster581
    Just to let you know that I solved the problem myself by not using the iPhone app and logging into the website http://10.1.2.3/ and configuring the Wi-fi link manually. I hope it helps if anyone else has the same problem.
  • Sam R.
    Thank you for the update, good to know and good to hear you're back up and running. I'll let the support crew know they can close the ticket I created.
