pulse flex is stuck in hotspotmodus (green light) after update player
4 Kommentare
    Wesley P.
    Hello Info,
    I'm sorry to hear you are experiencing connectivity issues with your Pulse Flex. I can see that you have already created a support request with our support crew. What I would suggest is to continue to work with them to find a solution to this issue.
    In the meantime what I would recommend is to verify that your WiFi password is correct as this would result in issues similar to the ones you have described.
    Wesley P.
  • Bill warbey
    my pulseflex is stuck with Green light on. My wifi network cannot find it and I cannot turn it on or off. Removing the power lead the light goes off but returns to green if plugged back in - the speaker is unusable
  • Sam R.
    Hello Bill,
    I would recommend redoing the WiFi setup process by connecting the Flex to the router via Ethernet (temporarily) and navigating to Settings > Player > WiFi in the BluOS app.
    If the issue persists however, please reach out to our support crew directly at support@bluesound.com and a member will be able to assist you further.
  • Nick martin
    I had this problem, I could not find my player or get it to connect to the wifi (green light stuck on). I resolved this by hard-wiring the speaker to my router via an ethernet cable. The speaker popped up at once and I could update the wifi connection, I then disconnected the cable and the speaker is fine.
    Hope this helps Nick
