Blue sound Pulse 2i rattles when deep bass sounds are playing
    Hi Gary
    This is not normal - if you are less than 30 days since your purchase, reach out to your dealer and they can help. If it's been more than 30 days, drop us a note by selecting Help, Send Support Request in the App.
  • Gary Burgess
    Many thanks for your reply.
    The unit is older than 3 months but the dealer has taken it back and returned to Bluesound for a repair I guess.
    Will post an update when I hear back from them.
    Gary
    Hi Gary
    No need to post update - you are in good hands.
