Folder contents not showing after re-sync library (Android)
10 Kommentare
    Hi Matthew
    I have escalated you to our Support Crew. They will be in touch via e-mail.
  • Peter Swanson
    On that particular album, are the Artist and the Album Artist meta tags different?
  • Matthew Wedd
    Yes, but I have thousands of tracks in compilation albums where that is also the case, and they show up fine. I set Album Artist as "Various Artists" for those. Here is a screenshot of one of the problem tracks' metadata from foobar2000:
  • Peter Swanson
    So Artist Name and Album Artist are different...
  • Matthew Wedd
    Yes they are indeed.
  • Matthew Wedd
    This has been marked as Answered but has not been. Is there a solution please?
  • Peter Swanson
    I think it is a software bug, but having trouble getting that acknowledged. See: https://support1.bluesound.com/hc/en-us/community/posts/34409923157143-Artist-Album-Artist-tagging-problem
  • Heinz R
    Unfortunately, different complaints about what basically seems to be the same problem result in different answers, for example see here: https://support1.bluesound.com/hc/en-us/community/posts/33609430555415-Issues-with-Library-New-since-latest-update
  • Matthew Wedd
    @Peter Swanson. Apologies I thought you *were* dev support.
    I've now seen similar posts and apparently a fix has been identified.
  • Peter Swanson
    That's OK! I think that what you (and a lot of other people) are seeing is an acknowledged bug. I have this message a little while ago: "Following discussions with our Engineering team regarding your specific issue, they have replicated the issue in our labs. Our Engineering team will conduct further investigation and provide a fix for this issue in an upcoming firmware update."
    Do keep reporting the problem, as it may help prioritise the fix.
