    Permanently deleted user
    Fairly certain you cannot do this as you have a NAD BluOS enabled device and not native Bluesound hardware but happy to be corrected.
    I quote from the Bluesound.com website product page…
    “Designed to use with Bluesound wireless speakers, home theater, or stereo components”
    Edit, should have said that there is a analogue input on the Sub that can be used
  • williamkeung
    i used the analogue input on the Sub still no sound. Did i miss any setup?
  • Permanently deleted user
    Please email NAD for support of your NAD C3050 support@nadelectronics.com They will be able to help you.
