BluOS 4.10.13 . : Autofill does not work on songs anymore.
    Hi Laurent\
    Our Quality Assurance Team is currently testing a solution to autofill not adding songs when playing from your local library. We do hope to publish a release in the very near future to address this.
    We do apologise for the inconvenience.
  • Laurent
    Thank you Tony.
    It's a shame that regression tests aren't being performed, because this bug could have been avoided.
    Can you provide the release date of the version that fixes this bug, because it's becoming very annoying not being able to use my Node ?
    Thank you.
    Unfortunately, we just missed this one. BluOS 4.10 was a major re-write compared to 4.8 as over a million lines of code were changed over a two-year period. Much of the code was very old. Some of it over a decade old. It had to be done in order to take advantage of the newer models chipsets and processing power.
    That being said, look for an update next week (Tuesday, August 5th) to address this and a number of other minor fixes to restablise your environment. That being said, I have escalated you to our Support Crew to provide you with more updated information. Look for an e-mail from them.
