Airplay connection problem an Tunein
    Permanently deleted user
    I normally find that closing all apps on the airplay device (phone / tablet) and rebooting it fixes Airplay. Saying that if you have problems with any streaming service along with airplay it could be a local network issue, Wi-Fi signal?
    https://support1.bluesound.com/hc/en-us/articles/201940663-What-should-my-Wireless-Signal-Strength-be-for-best-performance
  • Riste Krstevski
    Thank you Seppi.
    The Bluesound device is wire connected to the router, not wifi. I can use airplay on bluesound with the other internet radio apps without any problems on node132, with other cannot establish connection. On cambridge streamer works well all internet radio aps.
  • Permanently deleted user
    You try a simple reboot of the NODE.
    If that does no help in the BluOS App please select Settings, Send Support Request, so the Bluesound Support Crew can review the log file and take a closer look.
