Pulse 2 loose connection
BeantwortetHi. I have a older pulse 2.. now it loose connection.. flashes green.. try reset and with Ethernet.. works fine with wire, but when go to wifi it seems to connect and disconnect every second... Just now it plays without any connection and my Spotify do not play.. it plays for some second before it loose connection.. after some seconds it plays again.. spooky....
0 Kommentare
